Salta al contenuto principale
Repair guides and support for cars and other vehicles produced by the Chrysler division of the Fiat Chrysler Automobiles US LLC.
189 Domande Visualizza tutte
Digital read out on instrument panel not working.
I have 1994 town and country on the instrumental panel the battery gage works but the temp, gas,or speedometer will not. We replaced the ignition switch and checked the fuses. Help please.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
@grandmathersa ,Thersa Prior, Fuses you have checked, Try giving the dash a bang with your hand above the cluster to see if gauges come on or flicker, if they do it is a connection problem. Problem could be faulty instrumental panel(solder joint) connections issue, BCM (body control module) failing, Remove the negative battery cable for ten minutes and reconnect to see if it will reset. By looking through forums, In the past Chrysler has had a lot of cluster failures. Good luck.
http://www.automotivetroubleshootingsecr...
Punteggio 1
Aggiungi la tua risposta
Thersa Prior sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 65
