Salta al contenuto principale
First-generation Apple iPad with 3G capabilities. Model Number A1337. Available with 16, 32, or 64 GB of storage. Repairs are straightforward and do not require heat.
71 Domande Visualizza tutte
Domanda Chiusa
ipad...toss it in the trash?
I recently found an Ipad at work and after 30 days the owner didnt claim it. The passcode is impossible to decipher and each time I do it disables for longer periods between tries.
I can't restore through itunes.
What do I do...throw it out?
Questa è una buona domanda?
Punteggio 0
1 Commento
Please Recycle Your Electronics. :)
da
Aggiungi un commento
4 Risposte
Soluzione Prescelta
I don't think the USB port makes a difference. What does it say that makes you suggest that it needs the owners iTunes? BTW lucky find....
Punteggio 3
3 Commenti:
http://www.ipadforums.net/ipad-help/6037... your issues are addressed here as well
da
holy shniekee that last link worked! try a few times because it didnt at first.
da
Glad I could help. Hope you enjoy your find. Remember to return and mark accepted the answer that best solves your problem. Best of luck to you :)
da
No dont throw it out, what you do is connect it to a computer and have it open with itunes then you hold the power and the home button for a few seconds, afterwards it should say to connect to itunes thats going to wipe out the ipad completely and u should have a like new ipad
Punteggio 2
tried that...keeps wanting the original owners itunes. would it make a difference if I have 2.o USB port?
Punteggio 0
Put in DFU mode and restore
100% working solution
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,727
