Salta al contenuto principale
Calcolatrice scientifica di Casio con 252 funzioni e display full dot matrix. Dispone inoltre di una funzione replay e sette memorie variabili.
Why is my calculator showing a decimal as the answer?
Whenever I use my calculator, and do an equation, for an example, 2+2. It would always give a decimal as the answer when clearly it is not. For 2+2, it says 4.0 instead of 4. For 9.2+1.2, it says 1.0 instead of 10.4. I really don't know what to do because I have finals coming up soon.
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
4 Risposte
Risposta Più Utile
usually it is shift + 9 to reset all settings on a calculator to default
Punteggio 2
Try SHIFT, then MODE [SETUP], looking through the menu and selecting the mode you want.
Punteggio 1
2 Commenti:
How do I get a dot instead of a comma in my iPhone calculator?
da
Caoimhe, please create a new question on this in the main Q&A page. This specific question is on the Casio fx-82ES, so your question will not bee seen by our community.
da
just press shift 9, it puts all the settings back to normal
Punteggio 0
Yess this happend to me and the answer in press shift + 9 or shift , mode , 3 , = and again =
Punteggio 0
Aggiungi la tua risposta
Vanessa Mendis sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 30
Tutti i Tempi: 15,502
