How replace power button
please help how i can repair button phone dont turn on
Questa è una buona domanda?
@raw771 , Anton, Make sure battery is charged, try a different compatible charger if need be. Use the guide below to disassemble the device so you can disconnect the battery for 5 minutes,then plug back in and check/reseat all the connections to make sure all are connected well. Try and power on phone. Good luck.
Unless you have a micro soldering setup, you must either send it in for repair, get a new motherboard, or a new phone. You can, however, keep using your phone as is, just don't ever let the battery die.
Then whats the point of having a MOBILE phone? its anchored to the wall by a charger as (some) home phones are anchored to the wall by a jack.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 4,042
2 Commenti
I need help to find where to get a new power bottom for Asus Zenfone 2
da David
You can get it on Aliexpress.
da annmarie ward
