Salta al contenuto principale
Repair information for the 6th generation iPod nano. Released in September of 2010. Model Number: A1366.
175 Domande Visualizza tutte
iPod Nano 6th Generation LCD Adhesive Recommendation?
Hi all,
I just replaced an LCD on my nano. Looks good. Works fine. Only problem I am experiencing it with the adhesive. I bought the custom precut adhesives from ebay but they seem a bit too narrow. When placed on the ipod they seem to sit a little below in the recessed area so the LCD doesn't make enough contact with it to stick.
Anyone have any adhesive recommendations?
Thanks!
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
2 Risposte
Risposta Più Utile
@gob15 , Christopher, The 1st link below shows the recommended tape to used in the ifixit disassembly guide 2nd link. Good luck.
[prodotto collegato mancante o disabilitato: IF145-283]
iPod Nano 6th Generation Front Panel Assembly Replacement
Punteggio 3
4 Commenti:
Thanks for the links. Were there other options for the tape? The LCD I bought was the same price as the tape and shipped free! The shipping on the tape is half the price of the tape itself.
da
@gob15 search on eBay for the red "ultra sticky double sided tape", thin, strong and cheap
da
@reecee, @gob15 , Reece, thanks for the input,I believe this is the stuff in the link below.
http://www.ebay.ie/itm/2mm-25M-Ultra-Sli...
da
Thanks. That tape does seem thinner than even the pre-cut adhesive being sold for the nano. I can give it a try though and see how it works out.
da
Hi Christopher, also absolutely vital is to clean all surfaces with alcohol before trying to stick down. Also, I found that leaving the backing tape in place on the cable side until you have got the screen ribbons tucked in, really helps. Good luck ☺☺
Punteggio 1
Aggiungi la tua risposta
Christopher Cross sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 15
Tutti i Tempi: 1,261
