Salta al contenuto principale
Thermal Sensors Left/Middle/Right essentially the same?
I'm replacing the heat sink and thermal sensors in my A1260. Per product information, " The cable on the left thermal sensor is shorter than the cable on the middle thermal sensor and slightly longer than that of the right thermal sensor."
Being that this indicates the middle sensor is the longest, would there be problems purchasing 3 Middle sensors to replace all three? Currently, only the middle sensor is available on the ifixit parts store.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
That would be fine, yes. Aside from the cable length, those temperature sensors are identical. Routing a little bit of excess cable shouldn't pose a problem.
Punteggio 1
Aggiungi la tua risposta
riotdoll585 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 46
