Earpiece speaker not working after screen replacement
I replaced my screen, and now my earpiece won't work!!! I took it apart made sure all the flex cables are good and my connectors are clean... still nothing.
Questa è una buona domanda?
iPhone 7 Plus Earpiece Speaker
It happens to most people so make it simple and replace it.
having same issue. replaced speaker and flex w known good and still dont work
Then check the logic board and clean all of the contacts on the board
Any update? I have also tried both parts but without succes.
Hey everyone, i fixed this issue on a repair I just did
Essentially, I took it apart (following the proper steps) and then cleaned the connections with an alcohol swab and put it back together very carefully making sure not to touch any of the connections
Now it works
Which areas did you clean?
Like do I put the alcohol swab directly onto the connectors & let dry?
the little copper connectors between the earpiece and the flex cable, I had fingerprints on mine. I wiped it clean with the alcohol swab and then let it dry
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,266
Likewise here. We've had a 50/50 with replacing the flex and/or earspeaker. Hope someone can find a solution sooner than later. I'm going to purchase an iPhone 7 Plus assembly to see if this helps. I'll let you know if it's worth the extra the extra money.
da CellularRepairEtc
