Salta al contenuto principale
The Samsung Galaxy Note 5 (called the Note5) is a phablet-style phone with stylus, manufactured by Samsung, released in August 2015.
271 Domande Visualizza tutte
Galaxy Note 5 Wi-Fi and Bluetooth not working
My Samsung Galaxy Note 5 has problem with Wi-Fi and Bluetooth. Neither of them turns ON
I reset the device and didn’t work
The symptoms are: the Wi-Fi slide is OFF and grey, when sliding it to ON position it displays message “Wi-Fi Turning ON…” for few minutes and then it goes back to OFF; the same is with Bluetooth slide. I opened it to see if any wires were loose. All seems normal and all other functions of the device work fine.
Is it possible that the Wifi-Bluetooth modules are fried?
It looks like they are part of the mainboard. Can you suggest a diagnostic tools to determine if it’s in fact a hardware problem so I may start chasing the replacement part?
Thanks
Questa è una buona domanda?
Punteggio 1
2 Commenti
I think the microchip of wifi/bluetooth should replace it
da
I accidentally dropped my Samsung Galaxy Note 5 and then the wifi and Bluetooth won't turn on anymore. What seems to be the problem? Can this be fixed?
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
solution? . . . . . . . . .
Punteggio 0
1 Commento:
Does the phone have the latest update installed?
Also, did this just start happening or has it been doing this for a while?
da
Aggiungi la tua risposta
Omar Zn sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,588
