Salta al contenuto principale
Released in 2006, the 19" Dell Ultrasharp 1907FPc is a solid budget LCD monitor with four USB 2.0 ports, as well as VGA and DVI inputs.
How to fix 1907FPc 19" LCD Monitor feet from tucking?
it is stuck in the bothom
Questa è una buona domanda?
Punteggio 0
1 Commento
What is "tucking" and can you elaborate more on your problem
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
RENX , Check to see if there are removable plastic caps covering up screws that could be tightened to stop the screen from tilting. I had a stand that would keep tilting down on me and I wrapped a large an elastic around the hinged joint giving the problem and it worked. Good luck.
Punteggio 2
Aggiungi la tua risposta
RENX sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 383
