Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
Bent frame, what are the best alternatives here?
Hi all! I have a iPhone 6 with a screen flickering. I am replacing the screen, and selling it! Problem is, the phone has a large bend on the bottom. Screen almost fits, but there is a lot of air between frame and screen. I have the gtool icorner, and i was thinking i could invest in a head for the sidewall instead. Is this availabe somewhere?
The bend is pretty bad, and it goes trough the bottom of the phone. It is not just on the top where the gtool will straighten. I can also replace the housing, but that is of course a much bigger job, and i would hope straighten it up with gtool would work. What do you guys think? See pictures bellow! Ask me if you would like me to provide pictures from other angels.
Here you can see it with the screen mounted! There are no bottom screws installed here.
Thanks!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
It appears gTool does not make a side wall head for the iPhone 6.
I have used a combination of needle nose pliers to fix before, and filed off any excess.
You may also want to look at this tool: [prodotto collegato mancante o disabilitato: IF317-078]
Punteggio 0
1 Commento:
Thank you for the answer. It is a shame they don't make sidewall heads for iphone 6, because i have seen them for iphone 5S and 5. I will try to bend it slightly so the screen willl fit. Thanks. The tool was pretty expensive, i could rather buy a new fram for that price.
Have a nice day!
da
Aggiungi la tua risposta
Iver sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 425
