Salta al contenuto principale
Small media streaming device that plugs directly into your TV's HDMI port. Originally released by Amazon in November 2014. The latest version comes with a voice-activated remote.
116 Domande Visualizza tutte
Why aint my volume working on firestick. Does remote have a volume but
My volume works on tv but when I try to watch a movie on my Firestick i don't have volume. Does the remote have a volume button? What could cause this?
Questa è una buona domanda?
Punteggio 12
4 Commenti
I'm experiencing the same issue, Melissa. at 20 on regular TV, my Samsung TV is quite loud. watching a movie now using Amazon firestick, we have the volume at 50 and we can just barely hear it. if I find a real answer, I promise I will share. It's very frustrating!
da
Thxx helped me
da
Everything else works but my volume button
da
Thanks so much it worked for me.
da
Aggiungi un commento
20 Risposte
Risposta Più Utile
Okay, so I just had this issue. Hold down the home button until the settings option comes up. In settings go to “equipment control”. Go to “TV” and “change TV”. On screen prompts will walk you through from here. This was the issue for me. Hope this helps someone.
Punteggio 21
10 Commenti:
Nope, none of the selections ar TV or Change TV.
da
I had the same problem, did all the steps and still nothing. What I did was unplug the TV for about 10 seconds and plugged it back in and BAM that fixed the problem. Not the fire stick but the tv itself. I couldn't even power my TV off, but now everything is back to normal.
da
how can I put volume in fire stick tv
da
Unplugging the TV worked for me, Thankyou
da
Thank you so much, it worked!!!
da
Mostra altri 5 commenti
I had this! Couldn’t control volume or power on/off with fire stick remote. Did everything said on here, even turned TV off for 10 seconds but still didn’t work. I solved this issue for me by taking out the batteries on the remote!! Literally opened the back & switched the batteries around (didn’t replace them) & power on/off worked as did volume control so could be the batteries need replacing soon - hope that helps anyone googling the issue & coming here :D
Punteggio 8
11 Commenti:
Just tried that and it works. Thanks.
da
This worked!
da
I tried EVERYTHING and THIS was the only thing that worked!! Thank you
da
Been trying to find a solution for almost a year. Thanks!! It worked!!
da
That so random! It worked!!
da
Mostra altri 6 commenti
Go to settings -> Equipment control -> Manage Equipment -> TV -> Change TV
Follow what Firestick says and done.
Punteggio 6
3 Commenti:
You had the perfect response! Thank you so much! Fixed it right away
da
This was easy to follow and so simple. Thank for your help. Too easy.
da
When I go to settings it doesn’t give me the TV option when I go to equipment control it just says equipment control automatic or manage equipment
da
My problem was that during the TV/remote setup/config (Settings -> Equipment Control -> Manage Equipment -> Change TV) the only option that worked with the power and mute button wouldn’t work with the volume button. Volume up would not work at all, but the volume down would trigger the “AnyView Cast“ option for my HiSense TV.
I tired everything mentioned in this thread. The only thing that worked for me is this.
Take out the batteries from the Remote, Unplug Fire TV from the HDMI and power source and leave it off for 20 seconds. Plug the Fire TV back (HDMI and Power Source). Wait for the Fire TV device to boot. Once on the home screen, put the batteries back in the remote and press the Home button for 10 seconds (disregard the shortcut menu) your remote LED (top right) will now start blinking.
Wait for the blinking to stop and go to Settings -> Equipment Control -> Manage Equipment -> Change TV.
I followed the same configuration steps again but this time one of the combinations finally worked.
Now everything on my remote works.
Punteggio 4
3 Commenti:
Yes it actually worked. Thanks
da
i am facing problem with power button not working and also volume up and volume down not working.....
da
It worked. Fantastic. Thanks.
da
Finally solved my lack of volume control by changing where the Audio was being sent. To the TV not a Soundbar, since I didn’t have one. The TV had once been connected to one and who would have thought, duh! Just go to Settings, Equipment control, Advances settings, Volume control device.
Punteggio 2
1 Commento:
Thank you so much! This is what worked for me! I forgot all about our sound bar being connected!!
da
My remote didn't work for volume or power on or off tried all these suggestions nothing seemed to be working then tried to put my TV as wrong brand (mine is alba changed it to bush) eT voila it now all works
Punteggio 1
1 Commento:
Cheers, I also have an Alba TV, selected bush and the IR frequency works.
da
look around all over the stick to see if it has a volume or it went out or you need to turn the volume up on your phone
Punteggio 0
1 Commento:
we are asking about television volume, not phone volume.
da
The 4 way navigation key is the volume control also. Press upper side for volume up and down side for volume down.
Punteggio 0
Get close to the TV and press volume button up or down, it doesn't really matter till you see the volume on the screen again and then you can go more further it will work.
Punteggio 0
I've tried everything. My volume on my remote still isn't working, nor the mute. Everything else does.
Punteggio 0
2 Commenti:
Mine was doing the same thing. See my post below. Hope this helps.
da
I unplugged my tv and plugged it back it and it fixed, I have my tv on like 24/7 so it needs to reboot sometimes and then the remote starts working, it was the same when i use any remote, Fire Stick and regular remote.
da
Open settings >> equipment control >> check if it's set to automatic. If it's disable enable it and check if the issue is fixed.
Punteggio 0
1 Commento:
What if u dont have the option for equipment control?
da
Press the home button, go to settings
Select equipment control, then select tv..
Next turn power off and wait 10 seconds to power back on. Answer the question it will ask (yes)
Then you're all set…….
Gino Latino from Dallas TX.
Punteggio 0
I am facing the same issue as well on my LG tv as well as TCL TV…. So pretty sure its not an issue with the tv but its with the
Punteggio 0
Unplugged the fire stick from HDMI2 and connected To the HDMI 1 port on Samsung TV. And it resolved the volume issue.
Punteggio 0
Try following these steps ( Date- 20th Oct 20)
Home - Equipment Control - Manage Equipment - TV - Infrared Options - IR Profile - Change IR Profile - Select your TV brand name - Home
Try now . It should work
Note:
(Name of your TV Brand will be displayed if you have selected correct brand during 1st setup of Fire Stick
Otherwise you may try selecting diff IR profiles and check which one works)
Thanks
Sachin Pokharkar
India.
Punteggio 0
1 Commento:
unpluged 4k tv for 10 secs. and back on. Volume control worked!!
da
Just another possible solution:
This same problem was happening to me and I finally figured out that the bluetooth on my FireStick had connected itself to my AirPods that had been left out of their case. Once I put my AirPods back into their case, it worked just fine.
Punteggio 0
Thank you. It worked. Had to change to current tv I was using, it still had prior tv in settings.
Punteggio 0
If you hear volume when it starts up but not any other time, check to see if you have bluetooth headphones that might have connected. That was my issue, spent an hour till the headphones finally died and i saw the disconnected message.
Punteggio 0
Punteggio 0
The volume will not work
Punteggio 0
Aggiungi la tua risposta
Melissa Allen sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 10
Ultimi 7 Giorni: 77
Ultimi 30 Giorni: 263
Tutti i Tempi: 177,944
