Salta al contenuto principale
Use this repair guide to fix faulty parts in the Fujifilm FinePix S2980.
SD card will not insert
My SD card won't click into place in my camera like it use to, it won't lock in so I can't use the camera without the SD card
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
It may be problem with metal clips holding the SD card. Try to adjust them. I think camera has internal memory to place a few pictures without SD card.
Punteggio 1
1 Commento:
Thank you for your advice. I’ll try adjusting the clips.
I’m not sure if the camera has a memory, but I’ll look in the owner’s manual.
Thanks again.
Mike
da
Aggiungi la tua risposta
Emma sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 12
Tutti i Tempi: 179
