Salta al contenuto principale
Model A1059 or A1099 / 20, 40, or 60 GB hard drive / touch sensitive click wheel
227 Domande Visualizza tutte
Not responding to click wheel
I have just replaced the battery and fully charged it. Immediately the iPod began playing from my music collection, but I can't stop it or change the selection. The click wheel doesn't respond at all, so I can't do a reset. Docking the iPod on top of my Pure radio amplifier it plays perfectly, but...
There is no reception from headphones.
The click wheel behaves as if it is disabled by the HOLD switch.
This leads me to think that the ribbon connector to the headphone jack unit with its many fine connectors was not re-assembled correctly. It fit underneath the connector block and is impossible to see. If this was not in place, it could disable both the headphone jack and the Hold switch, effectively disabling the click wheel. Apart from the swelling of the old battery, there is no reason to believe the click wheel itself is faulty. Any ideas please?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
@ancestor if it would be the hold switch, the clickwheel would be unresponsive but it should not play immediately. My suggestion would be to replace the clickwheel first
Punteggio 0
The iPod played the last piece of music that had been selected when the battery failed. It played only that piece, it did repeat it, but then stopped, and I can't get it to play anything. The screen lights up with the selection - Music, photos etc, but I can't select them. Why would the click wheel have failed? It had been working until the battery swelled and then it wouldn't click.
Punteggio 0
Aggiungi la tua risposta
Geoffrey sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 73
