Salta al contenuto principale
Guide di riparazione per telefoni cellulari Android fabbricati da LG.
Brand New LG K3 Not Powering On
I just bought a brand new LG K3 from best buy, and was excited to turn it on being the tech person I am....but to my surprise the phone did not power on! I thought it just needed to be charged. So I charged it for 2 and a half hours, and nothing. The only time something shows up on the screen is when the battery is removed and plugged into the wall. But then it just shows an insert battery sign. Is my brand new phone defective? Please Help!
Update (02/27/2017)
I charged it overnight.....nothing
Update (02/27/2017)
It did something! Idk what I did but I tried to turn it on and it showed he battery loading screen but then shut off. Before it was nothing! If i plug the cord in while holding the power button it actually shows the lg logo for a couple of seconds but I cannot get it to turn on. Though if I put my phone close to my ear while charging I can hear a ticking sound......is that worrying? Anyways I have it charging now and I will check on it when I get home.
Update (02/27/2017)
Any ideas? I got close when I got it to turn on for 5 secs showing the lg screen, it still does it but I have to hold the power button and plug it in. Only other sign of life is sometimes when I plug it in it shows a battery with a loading wheel for two secs then goes away....
Questa è una buona domanda?
Punteggio 0
2 Commenti
I got it to boot into the imei display and stay while plugged in so I'm gonna leave it for an hour and a half then unplug it.....hopefully this works!
da
I still recommend returning it... Another problem may occur directly or indirectly related to this one.
da
Aggiungi un commento
3 Risposte
Risposta Più Utile
@thatsfantastic since you just bought it I recommend that you return it. Now is not the time to try and repair it. You spend hard earned money on this so let Best Buy rectify this.
Punteggio 4
8 Commenti:
Well......I made a stupid mistake and tossed the receipt and the box........dang it
da
I'd still get after them. They should have a copy of your receipt.
da
any other suggestions?
da
start with a new battery. It is possible that it is shorted out. Also check your charger and cable. If you are using a computer to charge it, use a different port. BTW great avatar...
da
nothing..... :(
da
Mostra altri 3 commenti
This helped me My cellular phone is not working
Punteggio 0
I think I need a new battery. I got it to boot up perfectly with a different battery, but it is too big, and had to be held on with tape. Even with the new battery, I eventually got a notification in android saying invalid battery, which is expected while using a battery from another phone. They are only 16 bucks....
Punteggio 0
Aggiungi la tua risposta
Andrew sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 585
