Salta al contenuto principale
Backlight always ON after changing the inverter even if the mac is off
Hi
Backlight on the screen was not working, so I change the inverter from a A1226.
Now, if I just put the battery, my screen is lightning even if the computer is off, and when I put it on, it works fine except the luminosity levels on the keyboard.
My screen is a glossy one and I took the inverter from a matte screen. I also change the cable.
Any solutions ?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
fab.breek this is usually caused by an inverter issue. You said that you "so I change the inverter from a A1226." but did not tell us what exact model your computer is. In your case it is entirely possible that you have a wrong/different internal wiring inverter. Replace it with a proper model inverter and let us know what happened.
Punteggio 1
3 Commenti:
My computer is a A1226, is it possible to rewire the inverter ?
da
Most likely not and you definitely would not want to go down a Rabbit hole. I'd opt for just getting a proper one.
da
ok, i'm gonna try to find an other one, thanks ! i'll keep you informed
da
Aggiungi la tua risposta
fab.breek sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 53
