Salta al contenuto principale
Released in March 2013, identified by model number S500CA-SI50305T
How to boot from sad using USB boot windows 10
Hello,
I'm hoping to install an ssd in my laptop I'm planning on installing it completely blank then boot the laptop from a USB. Once I boot it from the USB will windows go right to the ssd or will I have to do something to save windows to the add so I can boot it up normally without the USB but instead from the ssd.
Thanks,
-Brad
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Brad --
You must install Windows on the new SSD before it will boot. If this is a replacement, I suggest that you clone the old drive onto your SSD before installing. There is free software available on the web that will do that.
Good luck,
Russ
Punteggio 0
Aggiungi la tua risposta
Brad sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 196
