Salta al contenuto principale
The Canon EOS 60D is a 18 MP DSLR (digital single-lens reflex) camera with an articulating LCD screen. The camera was released August 2010 and is identified by the EOS 60D printed on the front of the camera.
56 Domande Visualizza tutte
only one SD card will work with camera. Door does not close sd
Eyefi card will only work with camera. I tried others. The door to the SD card will not close. It works fine with the eyefi card, but I am afraid to remove it. I would like to take somewhere to have someone look at it. I think the pins on the card got messed up, and that in turn messed it up the inside of the camera. I just don't know.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
@tmat35 , Tammy , Sorry to here about your dilemma with camera. You don't know, we certainly don't know with out pulling the card out and seeing it. If you want to find out, best to find a good local camera repair shop, tell them the problem and have them take a look, diagnose and estimate repair. I wish there was more/better info I could give, maybe one of the other ifixit volunteers have suggestions also. Good luck.
Punteggio 1
Aggiungi la tua risposta
Tammy sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 50
