Salta al contenuto principale
Released in March 2013, identified by model number S500CA-SI50305T
12 Domande Visualizza tutte
Will I need a new windows 10 key?
I bought an asus s500ca without a hard drive I'm hoping to use a usb boot I downloaded from Microsoft and I was wondering if when I boot it up with this usb will I need to enter a new product key?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
What operating system originally came with this laptop? Both Windows 10 and 8 in later models had keys embedded in the motherboard. When you install, it will self activate with those keys.
Punteggio 5
1 Commento:
I'm here to second that. I work in PC repair and if it is a Windows 8 or above PC with an embedded key it should just activate.
da
It should let you skip applying a serial code. It will notify you continuously though. There are some sites that give out codes (cant post here). Be wary on such sites as many are a bit sketchy
Punteggio 0
Aggiungi la tua risposta
Brad sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 574
