Salta al contenuto principale
A 5", 3 pound personal random orbit sander made by Porter Cable and released in 2010
4 Domande Visualizza tutte
Motor runs way too fast but has no power, stops when in contact with b
Motor winds up faster than normal but has no power. Stops as soon as it has any resistance. I can still hear the motor humming. Brushes seem to be free moving.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
@cajamadi ,Peter, Sounds like the center hub retaining bolt may of came loose or hub may have cracked/stripped not holding tight on shaft. Disassembly guide link below may help in diagnosing your issue with the sander. Good luck.
Porter-Cable 382 Fan Replacement
Punteggio 2
Aggiungi la tua risposta
peter sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 203
