Salta al contenuto principale
Processore quad core Intel Core i7 da 2,2 GHz (3,4 GHz con Turbo boost), 2,5 GHz (fino a 3,7 GHz con Turbo boost) o 2,8 GHz (fino a 4,0 GHz con Turbo boost) con 6 MB di cache L3 condivisa.
773 Domande Visualizza tutte
Is there any guide for change thermal paste?
HI there,
newbie have a question.
1. How & when we should change thermal paste ? i read some article said that we need to change thermal regularly, is it true ?
2. is there any guide that showing step by step to change thermal paste ?
Thank you
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Soluzione Prescelta
Its never a bad idea to replace thermal paste . This video can help with the process . Also don't cheap out on the paste quality
Punteggio 2
I agree with @jimfixer that changing the thermal paste is a good idea. The i7's can get pretty hot if you are doing some high end activities, such as gaming, graphics editing, or even simple web pages full of Flash. I suggest Arctic silver. You only need a thin layer with that. The idea is to get as thin a layer as possible to transfer the heat directly from the processor to the heat sink instead of heat getting trapped and built up in the "grey goo" first.
Punteggio 2
1: There is no need to change thermal paste in the whole expected life of the device (3 years). If you want to use the machine for more than 5 years, change it then.
2: Apple has official repair manuals for thermal paste changing, but they are just being through. You shouldn't have to read a manual to change some grey goo.
Punteggio 1
Aggiungi la tua risposta
yogie sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 214
