Salta al contenuto principale
The GoPro Hero5 Black is an HD waterproof action camera released by GoPro in October of 2016. The 4k resolution video camera has voice control, a touch screen display, and built in WiFi.
The LCD screen has a hairline fracture
I purchased my GoPro about a month ago - and the GoPro Hero LCD screen has a hairline fracture! I just took it out the case after using it - and the crack appeared. I did not drop of doing anything that would impact the camera. Has anyone else had this issue? and or know how to repair it or warranty the camera?
Questa è una buona domanda?
Punteggio 2
1 Commento
Is it still waterproof
da
Aggiungi un commento
3 Risposte
Risposta Più Utile
Are you sure it's cracked? And is everything on the LCD still visible?
Punteggio 1
2 Commenti:
100% cracked. LCD still works fine
da
@jezza even if it is cracked, if it is visible I wouldn't worry about it. But if it develops black spots then replace it. Even if you replace it it would probably still be pretty expensive as the device is still new.
da
Where could i go to get it replaced?
Punteggio 0
I noticed mine was cracked this evening too. Hasn't been dropped or abused in any way. I think this is a protective glass over the LCD screen, since the LCD screen still seems to work fine.
Would be interested know how I go about getting it fixed.
Punteggio 0
Aggiungi la tua risposta
Jezza sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 10
Tutti i Tempi: 4,460
