Salta al contenuto principale
Rilasciato il 19 settembre 2014, è la versione con schermo più grande (5.5") dell'iPhone 6.
1525 Domande Visualizza tutte
Siri and Front camera video audio static noise
Hi, I have a iPhone 6 plus that has recently developed a issue where siri can't hear me and the front camera video audio is loud static, Also headphones with remotes and mic's built in sometime don't work unless shoved in the socket with a bit of force.
The housing is needing to be replaced and was thinking it could be the lightning and headphone flex cable could be the root cause of the issue.
Hope someone has solved this issue before
Thanks
Lloyd
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
There are 3 microphones in the iPhone.
The bottom microphone is for Voice Memo and phone calls. The other microphones serve as error cancellation
The (top) front microphone is used for FaceTime calls, Siri and selfie videos with the front camera (FCAM). The top back microphone serves as error cancellation
The (top) back microphone is used for videos with the rear camera (RCAM). The top front microphone serves as error cancellation.
You may have two separate problems here, related to the damaged housing.
Lightning Port
Front Microphone
Otherwise, there may be something wrong with the audio circuitry on the logic board.
Immagine iPhone 6 Plus Front Camera and Sensor Cable
Prodotto
$9.99
Immagine iPhone 6 Plus Lightning Connector and Headphone Jack
Prodotto
$29.99
Punteggio 2
Aggiungi la tua risposta
Lloyd sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 13,759
