Salta al contenuto principale
iPhone di quarta generazione. La riparazione è semplice, ma il vetro anteriore e l'LCD andranno sostituiti insieme. GSM / 8, 16, or 32 GB di memoria / Modello A1332 / Nero e Bianco.
2375 Domande Visualizza tutte
Strange Display issues on Boot iPhone 4 (White Conversion)
So I successfully swapped the black for the white iPhone 4 front and back from the whiteiphone4now website. The only strange thing I've noticed is on powering up the device (after shutting it down). The first time I powered on after the conversion, the screen threw up a bunch of messages regarding my gmail account, etc. Then it seemed to be ok. I then powered down and powered back on. The second time, a few of my letters on the keyboard wouldn't work initially (when I was trying to type my iTunes password to update a fews). Eventually it started working again. Finally I just powered down and powered back up and everything appears to be working fine.
The random issues on the first two sessions concerned me Is it just something the happens when you replace some hardware? Anything that could be causing it that I should address? Maybe I am paranoid, but the random nature of it the first to cycles concerned me.
Thanks (in advance) for your help!
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Risposta Più Utile
Not sure what would cause this specific issue. Has the phone been jailbroken Or Hacked? (Could be an issue with the OS). Sounds like your iPhone 4 could benefit from a fresh restore of 4.2.1. Let us know your results I am interested to find out what happens. Good Luck!
"Logic will get you from A to B. Imagination will take you everywhere." Albert Einstein.
Punteggio 1
Aggiungi la tua risposta
renegrub sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,676
