Salta al contenuto principale
Released on November 22, 2005, the Xbox 360 wireless controller is the primary game controller for the Microsoft's Xbox 360 home video game console.
My Xbox 360 wireless controler wont do anything.
So I got a used Xbox off Craigslist and some of the remotes had battery acid corrosion on them. So I clean them with lemon juice and now nothing happens when I try and turn them on nothing happens. NOTHING!!!!! Please help!!!!!
Questa è una buona domanda?
Punteggio 1
3 Commenti:
Were are the battery contacts and how do I know if they are bad? Does it make a difference if I'm using AA's or not?
da
Yes you need to use aa batteries, along with the battery shell that the batteries fit in to. The contacts are just the metal part where the batteries sit on top of. Make sure they are not corroded or bent otherwise the controller won't be getting power from the batteries
da
Ok how do i know if the battery contacts are bad
da
Aggiungi un commento
1 Risposta
Hi you would need to dismantle the controller and clean the battery contacts with isopropyl alcohol and a toothbrush, if they are really bad and that doesn't work, then you would need to buy replacement ones
Punteggio 0
1 Commento:
The battery contacts are the metal part where the batteries sit and if they look corroded then most likely you would need to purchase replacement ones and solder them on
da
Aggiungi la tua risposta
Parker Collins sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 14
Tutti i Tempi: 1,159
