plug in the back of the gps
the end that you plug the adapter to at the back of the gps is broken. Is there a replacement part for that.
Questa è una buona domanda?
@darryl1972 ,Darryl, If still under warranty, use warranty for repair/replacement/refund. You can use the guide link below to see how to access the inside of GPS and possibly solder the old port back to board or have a good computer repair shop do it for you because it really is not a good job for a beginner to try. If you do need a new port you can do a search using the old one to match up to a replacement. The second link is a guide to show how the port is soldered back on. Good luck.
Guida
Difficoltà:
Difficile
15 minutes
Guida
Difficoltà:
Moderato
10 - 15 minutes
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 192
