Salta al contenuto principale
L'HTC HD2 è uno smartphone prodotto da HTC che utilizza il sistema operativo Windows Mobile 6.5.
installation guide of the motherboard?
Hello and congratulations for the site ....
My problem is that HD2 is no longer able to start some time.
by the various attempts I made with technical, it appears that the problem is the motherboard.
If you can put a guide on how to mount it and maybe buy it from you.
Thanks and good luck!
Questa è una buona domanda?
Punteggio 2
2 Commenti
Is this item water damaged at all?
I will be making a tear down guide soon.
da Condividi
The motherboard will be too expensive to purchase. You can find a working HD2 with a cracked screen or broken LCD and buy it and use the board from it.
If you have insurance through the carrier, pay the $135 and get a replacement phone. (It's $135 for T-Mobile).
da Condividi
Aggiungi un commento
1 Risposta
Risposta più utile
If you are interested in checking out the teardown and to replace your motherboard, here are the guides that i use. http://forum.xda-developers.com/showthre... and http://pocketnow.com/hardware-1/official... good luck
Punteggio 1
Aggiungi la tua risposta
Michele sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 8
Ultimi 30 giorni: 30
Tutti i Tempi: 9,006
