do I need adhesive strips after battery replacement? diy?
I will replace my dad's battery for 5s. Do I need to have adhesive strips for the battery? if so, how do you make it at home without buying?
Questa è una buona domanda?
You will need it for a proper repair. Otherwise the battery will slide around in the casing, which is a potential fire risk, just look at Samsung.
If you don't plan to take the battery off again, use double-sided tape.
@tomchai can you use glue or something? if not, how do you make double sided tape if u don't have any.
@tomchai Can you use super glue?
When you order the battery, add the battery adhesive to your oder.
I already have the battery not the strips
Go buy some double sided tapes then. You don't do repairs if you don't have this don't have that don't have anything.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,908
