Salta al contenuto principale
Asus ZenPad Z8 Model Number: P00J Released June 2016 Verizon exclusive. Asus ZenPad Z8 is powered by a 1.4GHz hexa-core Qualcomm Snapdragon 650 processor. It comes with 2GB of RAM.
Setting up email signature in ZenPadZ8
Can anyone help me get a signature set up in email (pop3 - not gmail) that is more than 1 line? The field for Edit Signature is a 1-line field and no return key. I've looked at keyboard settings, I've typed out all the info on the one line (it runs all together on a test email), and I have typed it out properly and cut and pasted into that field (same thing - all run together on one line). I have chatted with ASUS who lieterally told me they don't help set up email. I have the email downloading fine, I just need help configuring the table to accept a 5 line signature.
Help?? :-)
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
usually you cannot modify it more than past that, there are 3rd party apps that you can use to get better signatures with more lines of information images etc. into your signature but natively the system wont allow for it.
Punteggio 1
3 Commenti:
Can you suggest a 3rd party app? This was a surprise for us as it's replacing a Samsung tablet that had no problem doing a 5-line business email signature. Thank so much for the help!
da
you can use either of these they should work for you, depending on how elaborate your signature needs to be https://play.google.com/store/apps/detai... or https://play.google.com/store/apps/detai...
da
Thank you so much!
da
How to Create Gmail Signature on iPhone and android
Punteggio 0
Aggiungi la tua risposta
kathleen sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 186
