Salta al contenuto principale
This Samsung Tablet was first released in May 2015 and can be identified by its 9.7 inch diagonal screen. The model number of the device is “SM - T550.”
44 Domande Visualizza tutte
My tablet will not turn on or charge
My tablet will not charge an does not show charging icon so there fore will not turn on at all as it ran completely flat
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
3 Risposte
Risposta Più Utile
Why won't my tablet charge or turn on?
see it
Punteggio 1
Plug one of these to your charger
if you see the battery charging then there are some other issues. bad battery, bad cable or broken charge port. USB Ameter.
Punteggio 0
Not always there are 4 wires connecting the battery, and if you pry it off sometimes you can break a lead this is what is causing mine not to charge after opening it, and there is no fix other then sending it to samsung, it takes some microsoldering.......and no one in the area does it....
Punteggio 0
Aggiungi la tua risposta
Claire sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,093
