Salta al contenuto principale
Released April 2013, model numbers GT-N5100 (3G & Wifi), GT-N5110 (Wifi), and GT-N5120 (3G, 4G/LTE & Wifi)
System UI has stopped
When trying to close apps on my note, I get the box that says, "Unfortunately, System UI has stopped>" How can I fix this?
Questa è una buona domanda?
Punteggio 2
1 Commento
I can not find anything of one u beta on my phone and I have not had update for December that you hope to find in January that this is a rip off or not this is something like getting windows ten on your computer
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
I had the same issue. Found several suggestions. I did press "volume up" and "home" while powering on which brought me to a maintenance menu. I chose the clear cache option. That did not seem to do anything. Next I went to the "Setup" and "Apps". I found the app named "Google App", cleared its cache and then removed updates (reverting to the original version). After that things seem to work okay.
I assume "Google App" will auto update again at some point and we'll see what happens then. In the meantime, I was happy to find a way to get things working without having to do a complete wipe of the system back to factory default.
Punteggio 1
1 Commento:
This was so easy. Thanks so much for the help.
da
Aggiungi la tua risposta
ltdeat sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 2,892
