Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
not charging or recognized
my iphone started discharging quicker then normal but would charge, recovered twice from full discharge to 100% but not anymore no response changed battery and moved motherboard to a different frame and lightning connector, any ideas? regards
(did the home and power button thing)
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
5 Risposte
Soluzione Prescelta
Hello Mar. At this point, having changed the battery, insured you have a genuine Apple charger and swapped your MB into a known-good device, it is safe to say your issue is with the charging circuit on the logic board. This is commonly referred to as U2/Tristar.
This is a micro-soldering repair and is not DIY. If you don't have the right tools or skills, I would encourage you to find a micro-soldering repair shop to do this for you.
Punteggio 2
3 Commenti:
afraid of that, thanks
da
could that have ruined the earlier batteries?
da
That's hard to say. Your phone is old so the battery was probably on its death bed anyway. The Tristar IC is more of a communication chip even though it's always associated with charging problems. It is responsible for recognizing anything connected to the Lightning port. So when it fails, it doesn't recognize that a charger is present.
The actual "charging" IC is Tigris. If it was supplying incorrect current or voltage to your battery then yes, it could have damaged the battery.
da
Try a known good battery, are you using an original apple charger or an aftermarket one?
Punteggio 1
Hi your charger may be faulty try another charger.
Punteggio 0
1 Commento:
thanks done that is also not recognized by itunes
da
i would say just a new charger but if you already tried that then what i do is i just get a small pin needle and just poke around in the charging port for a while and dig out lint or even wood yes ive seen some wood in a charging port and just clean it out really good then try it and if not i would just put in a new flex cable charging port in it and try
Punteggio 0
3 Commenti:
thanks done that, cleaned contacts with isopropyl, no go
da
ok we are a bit further, bought a new iphone 5, interchanged motherboards and success downloaded my movies overnite the phone discharged completely again so it seems a short in the motherboard? any possible remedy?
da
honestly when it comes to logic boards i dont have a clue a bad board is a bad board just check the contacts and make sure they arent bad if they look fine it goes into the stuff i dont mess with sorry man
da
This sounds like logic board issue i.e. u2 charger ic needed to replace, this can not be done by you, so you have to take to mobile micro-soldering repair shops.
Punteggio 0
Aggiungi la tua risposta
Mar Schrammeyer sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 151
