An 18V battery powered angle grinder first introduced by RYOBI in 2014. It was released as part of RYOBI's ONE+ system of tools that all operate on the same battery pack.
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
1 Commento:
If you run the motor and turn the tool upside down, or possibly with the tool head pointing down, does it make a grinding noise?
If I had a tool that had a working motor, but wasn't spinning, I would first look at the motor shaft connection to the transmission gears, and transmission gears themselves.
da Geoff Ice
