Salta al contenuto principale
Third generation Surface Pro tablet, released June 20, 2014.
Hard Drive Connector or Adapter
I have a Surface Pro3 that was approximately destroyed. I managed to rescue the hard drive, but need to connect to it. Is there an adapter that will let me treat it like a regular SATA SSD?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
4 Risposte
Soluzione Prescelta
They do not use hard drive. They use solid state drives.
They use a mSATA interface. So you will need a mSATA to SATA adapter so you can plug it into a computer.
There might be a mSATA to USB adapter for convenience.
Punteggio 3
I believe what you are looking for is this:
https://www.amazon.com/Drive-Adapter-Con...
Punteggio 0
I believe what you are looking for is a Sata to usb Adapter which can be bought on Amazon.
Punteggio 0
Hi, Ben --
Thank you. I thought there would be an adapter, but I didn't know what it was called. I found mSATA adapters to both USB & SATA on Amazon.
I used the term "hard drive" as a generic -- old habit.
Thanks again,
Russ
Punteggio 0
Aggiungi la tua risposta
Russ Walden sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 3,992
