Salta al contenuto principale
Annunciato il 9 settembre 2015, l'iPad Mini 4 mantiene la potenza di un iPad Air 2 in formato più piccolo.
Sleep button not working
Hello there,
Just got an weird issue , i repaired an ipad mini 4th gen. everything works well except the sleep button wont work.
but it does work as power on/off .
i Know what most gone say now:
Bad digitizer , Nope tried 3 screens
tested screens on other ipad mini 4 and their it does work.
any had this problem to?
would love to hear how you solved this.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Transfer the Hall effect sensor, it's a small component near the home button. Without the sensor the machine asserts the cover signal as attached so the sleep/wake function is completely latched. The power button cannot be used for sleep/wake in this situation, only power off works.
Punteggio 2
2 Commenti:
is there guide for that? How is it done?
da
i know what you mean , but what if you trow it away already? can it be ordered ?
da
Aggiungi la tua risposta
briiangullentops sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,338
