The machine won't turn off. It goes through the cycle again
The machine won't turn off, when it is done spinning it immediately starts filling again and goes through the cycle again and again.
Questa è una buona domanda?
@barbeblom , Barb, sounds like a bad timer/control board allowing washer to keep cycling. Check the video below for more about a washer's timer function. You could try a google search using your make and model #. If not comfortable working on your appliance, have a good repair Tech. have a look, diagnose and estimate repair.Good luck.
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 30
Tutti i Tempi: 9,051
1 Commento
I have to manually stop the washing cycle and then put on spin cycle and manually stop it also. It won't go to the next cycle on its own.
da janetsillings90
