Salta al contenuto principale
L'Apple iPhone 5s è stato presentato il 10 settembre 2013. La riparazione di questo dispositivo è simile a quella dei modelli precedenti e richiede cacciaviti e strumenti di apertura. Disponibile nelle versioni GSM o CDMA con capacità di 16 , 32 o 64 GB nei colori Argento, Oro e Grigio Siderale.
3530 Domande Visualizza tutte
Possible Antenna issue effecting signal
Hi there,
I have a iPhone 5S on three which was working fine up until yesterday when the network ended up being stuck on searching. I managed to perform an update and this went away and it started to recognise the network, but then I noticed the signal kept going and it would say "No service".
Curious, I lightly tapped the bottom side of the phone and the signal came back. Now when using the phone, the signal drops and I have to tap it to get the signal to come back. My assumption is that the antenna must be loose but before I go opening up, I thought I'd see what you guys suggest here and double check exactly which antenna effects the mobile signal.
It's not longer under warranty as it's 3 years old.
Many thanks!
Stacey
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Not likely as the antenna is screwed in to the frame, even if its unstuck you should get a constant 1-2 bar signal in urban areas, more likely its IC related, in that a network IC is loose, given the model it may be a better bet to upgrade, we have attempted hot and cold treatment which lasts 1-2 weeks but permanent fixes are hard to come by and expensive.
Punteggio 0
1 Commento:
That's a shame. I've literally just upgraded to a 5SE and took out a sim only year contract for my wife to use that phone; so upgrading isn't an option now :(.
da
Aggiungi la tua risposta
whiteforestdogs sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 78
