Salta al contenuto principale
L'Apple iPhone 5s è stato presentato il 10 settembre 2013. La riparazione di questo dispositivo è simile a quella dei modelli precedenti e richiede cacciaviti e strumenti di apertura. Disponibile nelle versioni GSM o CDMA con capacità di 16 , 32 o 64 GB nei colori Argento, Oro e Grigio Siderale.
3530 Domande Visualizza tutte
Replaced front screen .
My cousin gave me her old iPhone 5s but the screen was broken and dangling by the connector cables BUT half of the screen was still visible and the full screen reacted when you touch it now I have bought a new screen replaced it transferred my camera ,homebutton, shield, etc. I watched a video and followed every step twice but my phone still will not power on I tried to charge it.. no vibration please help!!!
Update (01/26/2017)
Thank you guys for the answers but I tried again to charge it and it showed the dead screen so maybe the remaining charge just needed to drain before I could turn it on :) KEEP COMMENTING for others who may have this same problem
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
The 5S requires that you place all of the screws in the right place. They all have different lengths, sometimes only differing by 0.1mm. But if you put a long one in the wrong place, you can kill the logic board. Check out the guide to see if you possibly made this mistake.
The other common issue is when the battery is not disconnected prior to removing the screen. This usually affects the backlight circuit but it can cause other problems.
Go back through this guide and double check everything.
Punteggio 1
hi niannna
1st check the battery voltage minimum voltage is 3.6v if its not there change the battery or boot the your old battery and check.....
2nd check power flexi cable any damage
3rd connect to itunes its detecting or not in system
if its detecting pls let me know
Punteggio 0
Aggiungi la tua risposta
Niannna sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 67
