Salta al contenuto principale
L'Apple iPhone 5s è stato presentato il 10 settembre 2013. La riparazione di questo dispositivo è simile a quella dei modelli precedenti e richiede cacciaviti e strumenti di apertura. Disponibile nelle versioni GSM o CDMA con capacità di 16 , 32 o 64 GB nei colori Argento, Oro e Grigio Siderale.
3530 Domande Visualizza tutte
Long screw damage repaired but error 4013
Hey :)
I repaired a long screw damaged iPhone 5 today but when I want to update it (because its in recovery mode) it appears with error 4013...
-Im using a dc power supply
-I tried other cables, ports and pc
I had the same problem with 2 iphone 5s...
I repaired a long screw damage on the left bottom ( NOT Bluescreen Hole!)
Iphone had redscreen and after the repair ive not seen the redscreen anymore but both of them have also error 4013 problems...
What can i do?
Is it a nand problem?
On every iphone i can see the serial number when plugged in to itunes, so the nand is good or not? Can it show me the serial number and be damaged too?
What can i do else?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
The only thing you can do is recheck your repairs and look for loose loose joints and damage you may have missed the first go around. On the first picture there looks like a trace that has not been touched up on the left side. Do you have any pictures where the repairs are cleaner?
Punteggio 0
The red screen of death. Classic. Try disconnecting the front camera/proximity sensor cable and see if it works after doing a hard reset also.
Punteggio 0
Aggiungi la tua risposta
Mikail sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 460
