Salta al contenuto principale
Modello A1136 con 30, 60, o 80 GB di hard disk con plastica frontale bianca o nera
798 Domande Visualizza tutte
Problems with screen in iPod 30GB
I have a 30gb ipod with some problem but i don´t know if is a problem with the screen or with the graphic control. The screen is sometimes operative (i can use the ipod normaly) but in other times the screen shows bars crossing and is impossible to use then machine.
¿ideas?.
Thank you.
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
I would go the pass of least resistance and money. Check the connection of the ribbon cable to the circuit board, make sure it is seated properly. Also make sure that the battery does not exert any pressure on the display from the back. If that checks out I would plan on replacing the display. Luckily it is the cheaper part. If that should still not fix it I'd go with the main board. Do you have access to another ipod that you could use to test your display before replacing? Hope this helps.
Punteggio 1
Aggiungi la tua risposta
jose sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,762
