Why is my iPod when fully charged only last for 20 mim
ipod classic only lasting 20 min when fully charged
Questa è una buona domanda?
Its Time To Change The Battery ....
Hope It Works
Thanks
Varun
this sounds like you may need a new battery. no matter how good of a battery you have eventually if you use the device you will need a new one. battery have an finite amount of charges before alas even they die. the way you can tell if your battery is dying a lot of the time is if it no longer holds a charge for very long. I am sorry that this has happened to you and obviously you have used your ipod a lot over the years. I hope that this answer helps you out.
this is correct, you can see the steps here Sostituzione batteria iPod Classic **please be warned that this repair is very difficult
Thanks for your help do you know how much it is to replace the battery
might not be the exact model but this will give you an idea of how much it costs
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 119
