Salta al contenuto principale
Lanciato a giugno 2012. Modello A1278. Processore Intel con Turbo Boost. Fino a 512 MB di RAM Video DDR5
Battery status compromised after 340 cycles!?
Hi everyone!!
I own a mbp mid 2012, it's been a few days that the battery status says "Service Battery" , i checked with coconut battery and I've discovered that after only 340 cycles the design capacity is 70%!!
How is this possible? Could be just a software issue?
Thank you in advance for your help.
Questa è una buona domanda?
Punteggio 1
2 Commenti
Is this a replacement battery or the original?
da
it's the original battery.
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
The Battery May Just Be Defective You Never Really Know With Batteries Some Times. I Have Seen Batteries Go Bad After A Week Of Being New.
Punteggio 2
Risposta Più Utile
@yalkima , Yousssef, You could try contacting Apple to see if there is anything they would be willing to do because of low cycle count/charge. If no other recourse, see links below for guide on replacing battery and replacement battery available through the iFixit store. Good luck.
Sostituzione Batteria nel MacBook Pro 13" Unibody, versione metà 2012
[prodotto collegato mancante o disabilitato: IF163-019]
Punteggio 3
Aggiungi la tua risposta
Youssef Malkiya sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 198
