Salta al contenuto principale
Modelli MacBook Pro con schermo da 15"
8255 Domande Visualizza tutte
Why is my screen glitching with green lines and not starting up?
Hello,
My MacBook Pro is not starting up very well: it goes into the starting up screen (filled with green lines), shows a stripe of something like a test screen with all those colours, goes black for a second and turns completely white. It doesn't do anything after that.
My husband has installed better memory in my MacBook around half a year ago, and it's been glitching sometimes since then. It used to go away for a day or so if I restarted my device, but now it isn't starting up anymore. It would be awesome if someone could help me with this!
Questa è una buona domanda?
Punteggio 0
2 Commenti
It is essential that we know your exact model as there are known issues on different machines. Please go to the following link and input the serial number from the back of your machine and tell us what you have.
http://www.everymac.com/ultimate-mac-loo...
da
Apple MacBook Pro "Core i7" 2.2 15" Late 2011
This is my model, but I can't find where to ask my question?
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
hi elza evers first remove and put back ram and check may be ram someting loose connection will be there
Punteggio 1
1 Commento:
Thank you, will try!!
da
Aggiungi la tua risposta
Liz Evers sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 55
