Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
My iPhone boots to the Apple logo and then turns itself off. Why?
My battery has been poor recently. The phone will not stay on unless it is plugged in. I will get a new phone soon or fix this so it is not a huge deal, but now it wont even turn on! When plugged in (and even when not) it will turn on to the white logo screen, then immediately go black again. What do I do?
Questa è una buona domanda?
Punteggio 0
1 Commento:
Sounds like the symptoms do point to a bad battery.
This is a known issue for the iphone 6.
http://www.dailymail.co.uk/sciencetech/a...
Take it to an apple store, they will for free confirm whether it is a battery issue. I suggest getting a 3rd party to replace it for less, or even use an iFixit guide to do it your self.
da
Aggiungi un commento
3 Risposte
Hi Helenita
Step 1: Try To Restore With iTunes
Step 2: Replace The Battery & Check
Hope It Works
Thanks
Varun
Punteggio 0
The problem could be the battery. I would try to replace the battery, if that isn't working it could be the charging port? (Is the iPhone charging when pluging lightning cable in?
Punteggio 0
100% that when you replace the battery with a new one it will work,charging port is working ok !
Punteggio 0
Aggiungi la tua risposta
Helenita sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 605
