Salta al contenuto principale
4 inch display / Available in a variety of colors / Released in 3 different models / 16, 32, or 64 GB capacity
Is it safe to use this item?
I have the items to open my iPod Touch 5th gen, I have a new charge port to replace the old one with, is it safe to use a hair dryer to open the ipod with? And Will I need any glue or anything to put it back together?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Soluzione Prescelta
You might need more adhesive to put it back together and yes a hair dryer should be fine. Hope this helps.
Punteggio 2
3 Commenti:
Which one of these would be the best? Cause I don't want to buy something and it's not what I need...https://www.amazon.com/s/ref=nb_sb_noss?...
da
Actually, since you are repairing an ipod, most people use this and is similar to what is used on apple products. https://www.amazon.com/NIUTOP-Ship-Stick...
da
Okay so that's what I would need then to put it back together?
da
Yes But Don't Heat One Spot Too Much Or You Have A Chance Of Melting The Insides Other Then That It Should Work.
Punteggio 1
I would definitely have a professional look at repairing the charging port on this model. Saying this is a difficult task is an understatement even for professional micro solderers. The charging port is soldered with high melt alloy to the board itself. Basically this is a $@$* repair usually not worth doing.
Punteggio 1
1 Commento:
I would send it to someone, but I have no clue on who to send it to for repair.
da
Aggiungi la tua risposta
awilliams1nihs sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 139
