How can I permanently disable wifi from the 2ds
on the 3ds there is an antenna . the 2ds doesn't have it
Questa è una buona domanda?
you dont need to cut any cables, you can setup a PIN code to access the options and just delete all the internet connections and set the pin code up so that nobody can access the settings to setup a connection, pretty much the same effect as removing the WIFI antenna..
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,242
Other answers say parental controls. That solution does not work for me. The child still can call nintendo to disable them..
da Samuel Hilton
