Salta al contenuto principale
Il top di gamma Huawei nel 2016. Basato su un case unibody, ha una doppia fotocamera posteriore sviluppata in collaborazione con Leica. Può avere 32 o 64 GB di memoria interna e sei diverse finiture esterne. I numeri di modello sono EVA-L29, EVA-L19 ed EVA-L09.
72 Domande Visualizza tutte
Camera and led not working huawei p9
Recently, i broke the screen and had the LCD digitizer replaced by a local guy. Upon replacement, the screen itself did not sit completely flush and there was a small glimmer of light that you can see through the side of the digitizer; no biggie all seemed to be fine.
however now the LED does not work (i open the flashlight app and nothing happens), Nor does the camera app work. When I open the camera app, the app dies and doesn't open. When i try an app that would USE the camera, there is an error message saying "the camera is in use by another application".
So-- I'm unsure if the camera or LED worked prior to replacing the screen. I honestly didn't think to check. The screen was damaged pretty badly.
Ideas.?
I have called Huawei US and as this model (the p9) is an "International model" they (Huawei) will not help. Which is weird. but alas true.
I know that this phone is not in the US yet, but it seems that if I can't fix it, it is a big risk to buy another knowing that if I break the screen, im screwed.. any ideas..?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
I have the same problem but after a battery replacement. The flashlight works however, but I had to activate it from the lock screen the first time (it was blacked out in the notification/quick settings)
Punteggio 0
Aggiungi la tua risposta
Chuck Colby sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,478
