Salta al contenuto principale
Modelli A1419 / Fine 2012 / Processori 2.9 & 3.2 GHz Core i5 o 3.4 GHz Core i7, ID iMac13,2
330 Domande Visualizza tutte
iMac 27" EMC 2546 changing a component on the logic board
Hi
A have a big problem with my imac, I have to change an electrical component but I don't know the reference ? If somebody know or have an electric laptop schema please ?
[[URL=http://www.hostingpics.net/viewer.php?id...][IMG][/URL]]
Thanks
Questa è una buona domanda?
Punteggio 1
4 Commenti
@feya what is the 820-XXXX number on your board?
da
Hello oldturkey03
I have only found this reference CJ3B 31PlQMB0070
thx
da
And this reference C023113003FF651AK
da
Feya, I have this exact same problem!! This has to be a design defect. Same resistor blew out on my board and my screen won't come up. Did you find out what the value of the resistor is? Thanks in advance!
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
@feya old question and only answered for completions sake. That is reference designator L9500 which is a 250 Ohm ferrite bead (fixed inductor)in a 0603 package.
You will need to check why it blew the way it did. There should only be 12 Volt on that rail, so make sure you have no short anywhere else.
Punteggio 1
Aggiungi la tua risposta
FEYA sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 6
Tutti i Tempi: 187
