Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1687/A1634. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
1041 Domande Visualizza tutte
Issues after housing replacement
I changed the housing along with a new lcd on my iPhone 6s plus.
When I turn it on. It sometimes works and sometimes doesn't prompting the plug in charger icon. But oddly it will actually turn on sometimes and after a 10 - 20 seconds will shutdown with no notice.
Does this mean the battery has been damaged during housing replacement.
Secondly the antenna on the top left wasn't coming off as I didn't know about the hidden screw under sticker and I ripped it off.
Now the little plate on the back has broken off but I sandwiched it back and screwed it down. Should I replace with new one?
Update (01/03/2017)
ok switched battery and now problem solved.
i have a new issue now. The volume button randomly presses itself especially the vibrate rocker? does the flex for volume need to be changed?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
original flex solved issue and it seems i had battery issue too. now all is working fine
Punteggio 0
Risposta Più Utile
Housing replacements are, oddly, more tricky than it sounds. The first problem could be a bad battery. The second problem sounds like you need to replace it with a new one for sure
I know you probably have figured this out. But I'll post a guide, just in case
This is the antennae in the top left
Punteggio 1
1 Commento:
they all 6 plus parts buddy. ihave 6s plus
da
Aggiungi la tua risposta
Obahan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 107
