Salta al contenuto principale
Apple released the slimmed-down, buffed up iPad Air on November 1, 2013 in a choice of Space Gray or Silver. It packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
577 Domande Visualizza tutte
My iPad Air will not charge. The female port is damaged.
I took my iPad Air into Apple to see what was wrong with it. It was determined that the female port for charging was damaged. They offered me a refurbished iPad Air for $350. Can this be fixed?
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
3 Risposte
Soluzione Prescelta
Luckily, Ifixit sells a replacement port for your tablet for only $20. The item code is IF128-007-1. But I recommend cleaning it like Ben said first. If that fails, buy the replacement and follow ifixit's guide to replace it.
Punteggio 5
2 Commenti:
Thanks to both of you!
da
I have this problem for ipad air 2. The female connector got pushed in and bent a bit (unlucky fall while olugged in). I don’t see repair instructions.
da
Lightning cable not plugging in fully? Clean out the gunk using a toothpick or equivalent to unblock the charging port.
Otherwise may be a bad charger port which if I remember correctly they are soldered onto the board which is not a easy thing to replace as it will require a lot of heat and experience.
Punteggio 2
I have the same problem contacted Apple they can fix it for AU$350.00
Punteggio 0
Aggiungi la tua risposta
Missy sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 16,676
