Salta al contenuto principale
Rilasciato il 19 settembre 2014, è la versione con schermo più grande (5.5") dell'iPhone 6.
1525 Domande Visualizza tutte
iPhone screen right side backlight dark
Hello, I just replace my iphone 6 plus screen. Following the step by step YouTube video after I turned on my phone, I find that the right side of the screen is darker than the left side especially on the top right. I attached a photo on how it looks. I've disassemble and assemble the screen before with my old screen but it never happens before. Can someone help me to see is it the screen issue or I did something wrong? Thanks a lot for your help.
Questa è una buona domanda?
Punteggio 3
2 Commenti
Push the LCD ribbon cable in more (of course not too much or you will be left with a ribbon connector stuck into the logic board when you remove it). Sometimes it is not pushed in enough and causes this.
da
Maybe the display backlight is uneven
da
Aggiungi un commento
4 Risposte
Soluzione Prescelta
Test the old display, to rule that out
Punteggio 3
Risposta Più Utile
If a new screen does not solve your problem, then you probably have a damaged backlight circuit. This may have happened by mis-aligning the FPC connector and causing a short through the circuit.
Specifically, check FL2025/FL2026 or the backlight driver IC (U1502).
Punteggio 5
1 Commento:
backlight driver for right side (U1580)
da
Cathode Emi filter bead needs replacing
Punteggio 2
1 Commento:
Ha people don't even understand that this is the right answer!
da
i have soltuion u asking for right side lcd dim light
1st u see home key or lcd jack
the lcd jack right side on tope side
A light filter( the hiding filter) on
home key jack slite le near u remove
filter and short or jumper by soldring iron
and ur prob is solved
Punteggio 0
Aggiungi la tua risposta
Jianfeng Huo sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 17
Tutti i Tempi: 17,056
